Wait, just read the title - is this the rear driveshaft?
It will be stuck unless you drop the center bearing to get a little more room to move it. It appears that you've done that, but make sure it's hanging down.
Then, you need to knock it loose from the flange. With the six bolts out, a few modest raps with a large ball peen. Failing that, a sharp chisel on the joint. Don't hit too hard as the bearings in the angle gear are taking the shock. It will be rusted in there tight.
