Once I had it apart, I chamfered the edges as described in the TNN.
Before I sealed it back up, I drilled a hole and tapped the bottom of the case for a drain plug. Note that I flattened and smoothed the case for a good seal. That took a bit of work on a flat surface. I used a diamond stone that I use for plane bodies and chisels, but any flat surface would do, and then an absolutely square/orthogonal hole is required for good sealing.
Here it is all put back together. I used the genuine Volvo Anaerobic sealant, new bolts and new seals, all provided in the kit I got from IPD.
Look closely, you can see the flat and the drain plug (14mm thread, gold plug magnetic drain plug). The thickness of the case only provided for about 3 threads, so I didn't torque it very tightly. I had a helicoil standing by to reinforce the threads, but so far, that's not needed.
Now, before it went back in the car, I replaced the collar spline...not easy, I had to grind out a flat notch to get enough purchase on the collar to lever it out. You can see the grinding here:
This is the collar before it came out. Ugly with rust, but, pleasantly, not stripped, or damaged that I could see.
