I'm not certain that it can be cleaned. It appears to be damaged finish, not just dirt on the surface. Brake dust will damage a finish if left on long enough...and that has the appearance of iron oxide that has damaged the finish. If I were going to try anything, it would be one of those products that dissolves iron chemically.
You might try CLR. I just had good success with it removing a multi-year buildup of oxidized minerals, though non-automotive, that nothing else would touch. But as the label says, test in an inconspicuous area first. I've also seen oven cleaner suggested on YouTube for cleaning major wheel grime build-up, but again you might want to proceed cautiously.
I got a buddy's CLR. With about teaspoon, undiluted, I tested one area. Let it sit for two minutes as directed (though with hot water). With wire brush, it looked promising after hosing with water. I poured on another CLR and let it sit for five minutes, then brushed it. That's the result in the attached pic. Manually using hand wire brush was better until I used my powered wire brush. If you look closely, you'll see the wire marks. Well, this was a test. I will report back after I get the wheel project done.
I cleaned up a set of wheels from the salvage yard recently. Gunk engine degreaser, an abrasive pad (similar to ScotchBrite), lots of elbow grease, and a power washer. Worked well. I didn't care about the finish. I was already planning on painting with Plasti-Dip.
Brett
