Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Sacramento, CA
    Default Oil Leak After PCV service
    With my car approaching 200K miles it’s running well and I have to keep it this way for as long as possible so last week as preventative maintenance I dropped the oil sump to replace seals and to check for any blocked PCV passages since I also planned to service the PCV system. The good news is all the PCV passages in the block and oil sump were very clean, no blockage at all.
    The bad news is after replacing all the parts in the PCV breather kit from Fcpeuro my car developed an oil leak from the front cam seal on the intake side, maybe both sides. All parts replaced were Volvo OEM parts. I even purchased a new banjo bolt but had a problem getting the bolt started in the manifold so used the original bolt initially.
    The one problem I had (other than with the banjo bolt) was the vacuum tube from the intake manifold banjo bolt to the elbow above the breather box is a hard plastic tube that crumbled into many pieces after removing the banjo bolt from the manifold and disturbing the brittle tube. There’s a Volvo part (30731007) that includes this tube along with the banjo bolt fitting with coolant connections that I needed for replacement but didn’t have it and I needed to the car back together so I used a new 4mm ID silicone hose. The hard tube has an ID of 3mm.
    Since doing all this work and now having a new oil leak I’ve done some more research why an oil leak may have occurred. I’ve read Howard’s PCV system information, which is very good and very helpful and also useful information from Lloyd Dobler about the newer revision banjo bolt with a check valve and how it can prevent too much crankcase pressure under boost.
    With this information I’m starting to suspect the hose I used with a larger inside diameter in addition to using my original banjo bolt I may have created a problem with crankcase pressure under boost conditions. Thinking there may be too much pressurized flow under boost through the vacuum hose I went back and replaced the original banjo bolt with the latest revision bolt with a check valve. It’s still difficult to tell if this has solved the new oil leak problem because there was so much residual oil on the engine (which I’ve cleaned off today) but I think it’s better because I don’t see fresh oil around the cam seal on the one I can see (intake) so more time will confirm if the leak has stopped, or not. The cam seal looked like it was leaking from around the outside of the seal and not the seal around the camshaft itself. It could be I just need to replace the cam seal or seals and the new leak is just a coincidence but with the recent PCV work I’m inclined to believe it’s related. A next step will be to measure the crankcase pressure at idle and under boost. I've already done the glove test and it's fine so need to verify when under boost.
    It’s hard to believe a 1mm difference in the inside diameter of the tube may make a difference but I do think the original 3mm ID hard tube is used as a restrictor under boost conditions since the older revision banjo bolt has no check valve and is free flowing. I would appreciate any other thoughts or experiences with this PCV system.
    I will offer these suggestions for others that go down the PCV DIY path.
    This is pretty good video on PCV parts replacement
    https://www.youtube.com/watch?v=oEOzIoVxO4s&t=737s
    It’s a fairly big job so get all the parts that are needed before beginning the job, you don’t want to do this twice, trust me. Get the new banjo bolt and the part with the banjo fitting and tubing, get an ETM and intake manifold gasket, copper washers for the banjo bolt and all the parts needed to change the breather box, hoses and clamps. A flex head ratcheting 17mm box wrench is almost essential in my opinion for this job and even better also having a stubby version of the same type of wrench.
    Be prepared if the banjo bolt doesn’t want to thread into the manifold. I removed the ETM and loosened the breather box to provide wrench room and also some wiggle room with the banjo bolt fitting since the hoses connected to it make it very difficult to get the bolt exactly aligned with the manifold. I still had way too many problems with the finicky new banjo bolt and after a couple of hours I just put the original banjo bolt back in since I was able to thread the original bolt into the manifold rather easily as compared to the new bolt. I later filed the end of the new bolt and the starting thread to help enable threading the bolt into manifold easier. The second time I installed the new bolt it threaded into the manifold instantly although this time I also removed the power steering pump and alternator, which provided so much more room to work and a solid manifold position to work with, it really was worth the extra effort removing the P/S pump and alternator as compared to fighting with banjo bolt the first time.
    Highly recommend doing do the extra work removing additional items to give yourself enough room for the banjo bolt installation. Start with the minimum of removing the fan shroud assembly and with a loose manifold install the banjo bolt, Howard mentioned tilting the manifold up on the driver’s side, which may help getting the banjo bolt started. If you’re still unable to start the banjo bolt then remove ETM for more wrench room and to enable loosening the breather box (2 10mm bolts ) from underneath the manifold, which can help better align the banjo bolt. The breather bolts can be tightened after connecting the banjo bolt. If still having problem with the banjo bolt then remove power steering pump, try again and if needed loosen or clamp and remove coolant hose to banjo bolt fitting and if this doesn’t work then move or remove alternator to provide more room. It’s really not that much more work at this point to remove alternator and it helps so much. The banjo bolt can be a real bitch to get back into the underside of the manifold so just be prepared to methodically do each additional step to provide more working room instead of fighting to start the bolt in the manifold, which can go on for a very long time based on my experience and that of others.
    Excellent PCV system information from Howard…
    http://www.volvoxc.com/forums/showth...176#post187176
    Great info from Lloyd Dobler here, he measured crankcase pressure on two of his Volvos and found each had 2 psi under boost on both car and both had the older revision banjo bolts. He updated with new banjo bolts and now 0 psi crankcase pressure under boost. His cam shaft seal had original actually pushed out of the head.
    https://forums.swedespeed.com/showth...=1#post2803169
    updated banjo bolt
    https://www.fcpeuro.com/products/vol...BoCM5QQAvD_BwE
    have this part on hand too
    https://www.fcpeuro.com/products/vol...BoC5_gQAvD_BwE
    One of these tools would have helped me with the new banjo bolt
    http://uniburr.com/
    Attached Thumbnails Attached Thumbnails pcv banjo bolt fitting.jpg   Old revision banjo bolt end view.jpg   PCV broken vacuum hose hard nylon.jpg
    Good info, FirstVolvo, hopefully using the new banjo bolt will solve your oil leak at the cam seal. Threading the banjo bolt back on the intake manifold was a bear when I did my PCV. I definitely used a stubby 17mm box wrench and like you suggest, I had to attach the banjo bolt first before tightening the other connections of that expensive long hose which wraps around the engine. It sounds like you may have saved some $ by reusing the hose itself and just purchasing the $42 part you linked to: "have this part on hand too".
    I blew a cam seal big time going up a steep mountain pass. This is what prompted me to do the PCV service. Oil had been pouring out from behind the intake cam (not easily visible) but I could stick my pinkie thru the cam and actually wiggle the seal back and forth because it had popped out. I say this because even after I had done my PCV service I still had to replace that blown out cam seal in order to stop the oil leak. Of course this requires the special cam-locking tool, removing the timing belt, etc., etc. Hopefully your cam seal is still working effectively even though some oil may have leaked out. Just something to think about if you find you're still losing oil...
    Sacramento, CA
    Even if the oil leak is fixed I probably should be thinking about replacing the cam seals. I'll need to get a cam locking tool so I've been looking at the different options. There are many unknown brands or unbranded versions of the cam locking tools at a lower price but I've been reading about people breaking the cheaper tools when dealing with the torque of the CVVT bolt. Are there any lower cost cam locking tools that are decent quality? It's one of those tools that I may use only once so I don't need a professional level quality shop tool but don't want something that breaks on the first use either, especially dealing with the cam timing.
    Nov 2012
    Pacific NW
    When I did the cam seals, I used the tool sold by IPD. I think it is available cheaper elsewhere, but I needed to get the job done. Also, I used the technique, where a sheet metal or drywall screw is threaded into the old seal to facilitate removal. This is difficult, and dangerous, in that it is easy to damage the cam or sealing surface.
    I wanted to use the Lisle seal tool, but could not obtain one quickly. If I were to do it again, I would wait for the correct seal removal tool.
    PDX-Vancouver, USA
    2005 XC70 140,000
    Sacramento, CA
    Quote Originally Posted by Scopeman View Post
    Scopeman, do you know the company name that manufactures the tool IPD sells? It looks like a CTA brand tool, which is a quality tool from what I've read. I have the Lisle seal tool remover from a previous project so that's covered.
    I bought the tool made by ABN from Amazon. About $66. Works well. Well made.
    Sacramento, CA
    Thanks Astro. I did see this brand on Amazon but there were more than few very negative reviews due to the tool breaking in use, the tabs that fit into the cam ends and bolts shearing off. I don't know what to make of the tool quality. Do you think any of the problems may be due to the users or is the quality of the tool just inconsistent.
    Worked OK for me. Twice. Still have it. Everything I’ve found otherwise is either no-name...or hundreds of dollars.
    I’ve never bought CTA tools, but here’s a possibility:
    https://www.fcpeuro.com/products/vol...SABEgLXGfD_BwE
    Nebraska
    Quote Originally Posted by FirstVolvo View Post
    You can't replace a hard, polyurethane vacuum tube with a soft silicone one. What do you think soft sided tubes do under vacuum? Unless the turbo is actively sucking air in, most PCV vacuum goes through that hose.
    The hole in the banjo bolt is considerably smaller than 3mm, more like <1mm, in which case it is the flow restrictor. Not the hole hole in the side or top mind you, the hole down inside the center of the bolt.
    Nov 2012
    Pacific NW
    Yes, it is a CTA brand tool.
    PDX-Vancouver, USA
    2005 XC70 140,000
