Not sure what or where you would find it in the States, but I use this one that I bought at CT. http://www.canadiantire.ca/en/pdp/ma...4574p.html#srp Probably available at one of the US parts places under their brand name I suspect. I view the image on the same laptop I use for VIDA. Pretty basic setup but for as much as I use it, it does work well enough. It was a Christmas present from my boys otherwise I probably wouldn't have bought one myself. But it has come in handy a couple of times and now that my geezer eyes are crap, it has allowed me to see some details that I couldn't quite get a focus on.
I will try a new cap seal and watch it for a short bit --assuming I do get it running that is .
I switched to synthetic maybe 18 months ago but always changed the oil at 3-3.5k intervals since i have had the car.
When I did the PCV I did change everything including the expensive hose (but believe I overlooked the cap seal). That was probably 30,000 miles ago.
Thanks all!
Gary
Ok - you are trying to get the car to start - and you have no fuel pressure - is there gas in the car? Is it possible the gas gauge is not working correctly and you are out of gas - yes. Have you tried simply adding gas?
your oil leak/tire pressure/phase of the moon is not causing the car to not start.
Hoonk, good suggestion, but yes I tried adding gas -about a gallon. No luck.
Also, yes I am aware that the oil situation/moon phase/Trump administration has nothing to do with the no-start.
Gary
A shot of starting fluid introduced into the intake of a car suspected of not getting fuel will give a brief run which then eliminates the ignition as a problem and narrows it down to fuel delivery,
Starting fluid sprayed at the MAF got the motor to catch for a second.
I got around to doing the fuel pump today and it is still not starting.
The pump is getting power and is buzzing, but still nothing coming out of either shrader valve after several times cranking the motor (maybe 10 times). Nothing leaking that I can see. Is it possible there is a big air bubble in the line? Anybody have this problem before?
I can only think of three possibilities: 1. air bubble 2. leak or 3. clog between the tank and the fuel filter. I would think a clog that bad would be extremely unlikely. Any other ideas? Feeling pretty foolish here...
Nice call albertj.
I put another 2 gal in the tank and it fired up nicely. Thank you for the advice.
Now I'll drive it for a bit and plan on a probable PCv job to deal with the oil puddling.
Thank you to all who responded.
Gary
U R welcome, the Volvo XC gas tank straddles the rear drive shaft and for some reason if the gas is sitting in the tank just so, then the pickup misses it. Is a PITA. I think another post documented the issue better. If you have 1/4 tank or less fuel, might want to visit a filling station before parking.
