I did a search for whine and nothing relevant turned up.
Just this morning a new noise began. It is a rather high pitched whine coming from the silver module located down below air cleaner box.
Anyone know what is is?
thanks
2007 xc70
thanks
2007 xc70
steve
old rocket engineer
2007 XC70
what is the vacuum pump for, the brake booster? why not just pull vac like other cars?
i found the vacuum pump in VADIS. where is the switch? thanks
my vadis only goes to 2005, is there a version for my2007
found it. not quite where wiring diagram puts it
as the switch is a direct feed from CEM fuse 33, switch must be faulty, disconnect switch and then reconnect and pump is off for now, I will get new one . thanks
steve
old rocket engineer
2007 XC70
Turbo cars have a pump, ALL makes, all models
There is not one on my 2001 and 02 US xc70. (both don't have variable timing on the intake either)
The pump is there because whenever a turbo is under boost, there is no engine vacuum to assist the brakes. Not all cars with turbos have a pump, assuming that you're not under boost continually you regain vacuum as soon as you let off the gas.
