I have a 2001 XC70 with 170k on it which suddenly wouldn't start this morning when I tried to leave work. When I first started it, it did fire up, but the idle was incredibly low and the car was severely struggling to stay running. The throttle was not responsive, so I shut the car down. When I tried to start it again after that, it wouldn't fire. It's not a battery issue, as it is clearly turning over. The check engine light has come on and it's throwing the "Engine System Service Urgent" warning. I tried disconnecting the battery and it still will not start. My immediate guess is the ETM has failed, but I'm not sure if it's the MAF Sensor. Last winter, the car went into limp mode on me once with the typical ETM symptoms. I had cleaned it, and it went back to normal. The other day the car started acting up again (lunging forward randomly at idle, delayed throttle response, etc.). The one day that I went to park, I had given it some gas to get through some snow, and then the RPM's started surging and the car lunged forward repeatedly. I shut it off and let it sit overnight. Then, last night on my way into work, the car was driving fine. The temperature has been severely low in my area this past week, so I'm not sure if that's a factor that caused the MAF sensor to die. Is it worth replacing the MAF sensor first to try and get it going, or should I just get an ETM from Xemodex? The car is currently sitting at my work, so I'm trying to find the best starting point to get it going. I'm in a pretty desperate situation, so any help is greatly appreciated!
