Hi, My 2005 XC70 has the two front power windows acting up! The drivers and passengers power windows ( with the two stage switch) seems to need something reset. When I press the window control all the way down (so the window should go up all the way and close by itself) the window goes up to the top (closed position) and then right away goes back down all the way. I think I recall a couple of times it would go up and then come back down about half way and stop. I would have to hold the window button in the close position until the window would go up to the top and I would have to hold the button for a second in order for it to stay up.
Is there any way to "set" or "adjust" the power windows so it goes up and stays there (without coming back down again)
At first it was only the passengers side that did this, and now the drivers side is doing it as well.
It seems like it must be something to do with how the power is told to stop once the window get to the top.
All help is appreciated.
