The rear shocks or struts have worn out on our 2003 XC90 after 171K miles. We get a lot of "hoopty mobile" bouncing going down the road...
Is this a repair that you can do yourself? The "shocks" are inside the spring, that I can see.
I found an "OEM/Volvo shock retaining nut strut removal socket tool" at Autozone for $24.99 part number 24365
Here is the link:
http://www.autozone.com/autozone/access ... umber=true.
Has anyone done this repair? Is it a no-brainer or do we need any special compression tools like for struts?
The Volvo dealer tells us that if the shocks are "Nivomat" shocks, then they cost $585 each. Ouch! They told us that there is a silver plate on the firewall or under the fenderwell which will let you know which shocks you have on your vehicle.
I hope that this is a simple 1-hour garage job because every repair on this vehicle seems to be more than $1,000. It would be nice to be able to do at least one repair on this vehicle myself )
Any links or diagrams would be greatly appreciated.
Thanks!
