I disagree with your repairman. This doesn't get better with time, only worse. The vacuum leak will eventually cause engine performance issues. When it gets worse, you will lose boosted braking...and that's dangerous. So, I agree with Tom and Ray.
I replaced the brake booster on my XC about 4 years ago. It's been fine ever since, lasting over 80,000 miles so far. I used a genuine Volvo part, purchased from IPD, which fit perfectly. I can't say if it's been redesigned. I can say it's lasted a long time and I don't anticipate its early failure.
I replaced the brake booster on the T5 last month. I used an ATE unit from FCP Euro...it didn't fit perfectly. Bolted in just fine, but the position of the brake pedal was off by a bit and I had to shim the brake pedal arm to get the stop light switch (which is not adjustable on this car) to work. I still wonder if my pedal height is correct...
You save about $100 on the ATE over the genuine Volvo, but I would go with genuine Volvo if I ever have to do it again. The installation is a pain. I had to open the system, remove lines and move the ABS module...
(By the way, good grammar is a courtesy to the reader...)
Astro
