If you've got a good amount of thread left (say, 1/2" or so) and your longer plug is engaging them, I think you're fine, as long as you use a new sealing washer and torque correctly.
IF it was mine, and I was worried about it, I would spend the $25 or so on a Timesert (1st choice, best quality) or a Helicoil (still works well) and just re-thread the fitting in the pan. Aluminum will cut easily with a good drill bit. You'll need a pretty large drill and bit set for this, but the new drill, new bit and timesert will still be less than a new pan... Used pan is an option...but still a bigger PITA than rethreading and using a timesert...
