So basically I went to start my 2003 xc70 the other day and the car started revved up to about 1500-2000 rpm then died. I took a look under the hood and I noticed that the booster vacuum switch (looks like three prongs with an electrical outlet attached to the top) was cracked and hanging in the engine compartment. I promptly replaced the entire switch with a new one from my local volvo dealership.
Now, the car starts runs for a few seconds (much better than it was before) but slowly dies. It sounds like the car is not creating a proper vacuum, but I suppose it could be something else fuel related. I am most certainly no expert. I have perused the forums for a similar issue and have come across no such problem.
Was the issue with the vacuum switch related or was it just coincidence? \
Thanks for reading,
J
Also the best way to describe the sound is when you start up a gas goped but you haven't pumped enough fuel into the engine or let it idle for long enough before accelerating. (If it helps at all).
