Hybrid View
Previous Post Previous Post   Next Post Next Post
    Jul 2013
    bc canada
    Lightbulb 99 steering lock acc only won't turn to ign or start
    Hello and Welcome me please and Thank You All etc
    New to me is a 99xc, sold my 88 765TiR IRS swap 20psi from the "K" block ipd springs sway stainless exhaust brakes 16"se wheels etc etc etc 800,000km purchased at 65,000km
    $35k invested sold $2k
    That volvo had one of the dreaded 4 sided keys. First trouble I drilled the Lock Cylinder out.
    within a few days with this new xc I have the same problem.
    My question, can I do the same thing. Drill out the lock. I live in the middle of NoWhere. So I am not concerned with theft (I was not with my 765TiR).
    I see the antenna ring, so I know I would need to use the key. But if the tumblers are out of the way???
    But there seems to be a couple extra locking points I do not understand.
    Does anyone know if I can look at the schematics/technical of the locking mechanism.
    Are there any other things that need to be done. Like the cylinder removed from the car. Then some other pins drilled out.
    I hate to dump too much money into this. I want to be sure it will be a long life with me. If there are many things wrong with it.
    Main reason I am hesitant to spill the $000 on a new one, is they are prone to failure. This is the same reason I drilled my 765 out.
    Just wanna make sure it will work if there are not any other things in-line.
    Thanks for being...
    Jul 2013
    bc canada
    rubber mallet worked
    welcome me
    Jan 2012
    Dearborn, Michigan, USA
    See "ignition lock problems? read this, save money" thread. A cheap way to use a junkyard (or Ebay) ignition lock cylinder coded to fit your existing key. Worked for me! Easy, cheap!
