If you want to be successful - then have a specialist rebuild the body.
I don't doubt that you can do the swap, but there is far more to rebuilding the body than what you've found on youtube or the web. The fact that you think you have all the tools tells me that you haven't fully understood what's involved. There are far more parts in the Valve Body alone than in any manual transmission.
Just the jigs to install the Sonnax upgrades (re-bore) are several hundred $$...I know, I looked...and the tool set (jigs) to rebuild the linear solenoids are a few hundred $$. The cost of the tools just to be able to rebuild it exceed the cost of having a specialist rebuild the valve body. But having the tools doesn't mean that you can do the rebuild, you still need to be able to adjust it when you're done.
Here's a link to the guys who did both of my valve bodies: http://www.valvebodybuilders.com/
Here's what they do to remanufacture:
Using a comprehensive three-phase process, Valve Body Builders remanufactures transmission valve bodies that exceed industry standards.
Phase 1: Test each individual solenoid electrically three times, flush with heated hydraulic fluid, test for flow and leak, then graph performance on computer to ensure the solenoid meets OEM specs.
Phase 2: Check and test each individual valve, install Sonnax upgrades as well as upgrades engineered by VBB.
Phase 3: Run assembled valve bodies through a complete series of shifting tests on using Zoom Technologies Smart Switch VBT 4000.
The end result is a valve body that's ready to work and to keep on working! Our remanufactured valve bodies come with a 12 month unlimited kilometers warranty.
VBB works closely with each customer, providing personal, hands-on service and a product that will keep their car lift free of technical problems.
VBB doesn't deal with consumers (at least, until I begged them to do mine) - they're focused on supporting transmission shops. Transmission shops who have found the valve body too technically challenging, that's why VBB has the flow bench, using heated fluid, to test and adjust the rebuild.
One other point, if you mess the body up, you'll find a new one is about $1,300...about twice the price of having a specialist rebuild the body.
The spirit of this forum is to learn from the experience of others....that's why I wrote the notes on replacing the valve body. I've done it twice. Learn from my experience: The best route is to take it out, send it off, and have a specialist do the work.
