Several simulateous issues.
Yeah, worn mounts cause the engine to vibrate more than usual, and yeah, I've replaced all of them. I found that the poly trans torque mount from IPD on my T5 added a bit of vibration, so it didn't go on my wife's XC...the Poly upper mount caused WAY too much vibration, so it came off the T5 to be replaced by the factory mount.
So, likely your problem is felt more because of worn mounts.
But, with RPM fluctuating, it's caused by something else.
T-belt off by a tooth? That would do it! It will also be sluggish on power (valve timing matters..and the ignition timing will be triggered by the crank...) and you haven't mentioned power...
so, first, fix the poor engine idle - that needs to be resolved.
Next, replace the mounts - you're due anyway, and then the engine will feel much better to you...
