Couple of thoughts
Your symptoms are from a sticking brake. Pulsing, the heat, the damage to the pads...all of it. But I wouldn't rule out the bearing until it's been checked. And "red hot" you say? This is dangerous - you can induce a bearing or brake failure with red hot brakes...
You say you've replaced the wheel bearing, so it can't be the bearing. Sometimes, new parts fail pretty quickly for some odd reason. So, eliminate that as a cause by checking it with the wheel off the ground...further, you want to ensure that it's not heat damaged now...
Then pull the rotor and make sure that the parking brake isn't sticking...
Once those are checked/eliminated, you need to determine the cause of the sticking brake. Most likely it's a caliper problem, as previous posters have replied. You need to troubleshoot this too, by (safely, please!) checking the action of the brakes. Get a helper to step on the brake pedal with the car up and the wheel off. The pads should retract just a hair when the pedal is released...just enough to clear the rotor.
If they don't, then it's sticking. If the pads are really unevenly worn (one is more thin than other) I would suspect the pins are binding. If they just plain don't retract, then it's the caliper.
Once in a great while, a brake line will fail internally, causing it to act like a one way valve. So, if you end up replacing the caliper, check the action of the new one to ensure it all works correctly.
Regardless of cause - I would replace both rear rotors and sets of pads once you've found and repaired the cause. One side is toast already, and you want to replace in pairs.
Good luck.
Reason: PB
