Alright. I'll begin this with a preface that I've probably read every post on every forum about anything Volvo. Still...I can't seem to rid myself of this problem.
1999 V70XC with 119,000 miles. It's my wife's care & she uses it to run a small business walking dogs. Recently replaced fuel pressure regulator, fuel filter, air filter, plugs, MAF sensor, all to no avail. Here's the jist:
Car runs fine & starts fine right in the morning. If you start it, turn it off, then start it again, no problems. If you drive to the store, shop for 20 minutes, come out & start it, it will stumble on start up & most often die. Try again & it starts like nothing ever happened.
Apart from the starting issue, the car runs very well. Gas mileage is VERY POOR (<15mpg). Yesterday, while my wife was driving, the CEL came on & the code read P1171. (This code is what prompted the MAF replacement). I've read the many posts on the P1171 code of death. What should I do next? Change 02 sensors? (how the *#&$ do you get to the front one?) How do I check for vacuum leaks?
Thanks for the help in advance.
Other relevant info: No leaky injectors, no black smoke from exhaust, fuel pressure good.
