Don't mean to spoil all the fun, but you guys are in for a nasty surprise when you have to replace the accessory belt tensioner. That 14mm bolt head is gone; you now have to use a T60 torx bit to move the damn thing and I tell you mister it is a royal PITA!!! You can't use the bit in the socket....you gotta take the bit out, stick it in the hole, and then try to double up two wrenches on it and even then it's not easy to get the throw you need to slip the belt on. Just a heads up lads as bleak days lay ahead!!
Dave.
