Hi All,
Just did the transmission flush and renew, the instructions I got were much the same as the link above. I did a lot of research before hand on the fluid type and quantity. I got the following from a long serving Volvo Master Technician. DO NOT USE ANY OTHER SPEC ATF The fluid was developed by Mobil for Toyota ( for the AISIN gearbox range) the Mobil 3309 the Toyota Type IV (type 4) and the Volvo fluid are identical,( probably all made by Mobil) other manufacturers produce 3309 spec fluid also but why go there when this is an infrequent fluid change. I was advised to use 10 Litres of fluid (2.5 Gal US), using more is of little benefit and any less will not suffice. Our Mobil distribution is not great in Ireland so I was left with Volvo or Toyota. Volvo fluid cost 4 times as much and would take two weeks to get it in, Toyota had it on the shelf.
I took my time doing the job and kept everything very clean, the car runs much smoother now, and I will definately do this again in two to three years.
the master tech said not to bother too much with the clarity of the fluid as a guide to progress just keep going till you have flushed 9.5 litres take it for a run and top up if necessary, do not overfill.
