does anybody know the differance between the grey and white buld holder
i know its an older post but i just wanted to confirm that the micro bulbs from The Source.ca AKA Radio Shack work just fine,,,you just have to use the original plastic base housing,,replace the bulb and put it back...the bulb itself is almost half the size of the original bulb,,but its not loose or anything...after weeks of darkness ,my ecc panel lit like a christmas tree again lets see how long they will last.. ps . i didnt use the blue condoms from the old bulbs as they were discolored and they were too big for the radio shack bulbs...i didnt see any difference on the light of the panel..
i did not disconnect the battery , i just have disconnected the lighter plug from behind of the ecc panel and turned it over and worked on the bulbs,,,there is definitely enough room to work without disconnecting the ecc plugs...but the key has to be in the contact and turned on cause the shifter needs to stay at D to give you enough room to get the panel out and turn....the bulbs had to stay on during my work...it didnt feel good but i was very careful not to touch any metals around,,,finished replacements without any problems
I would recommend using the Neo Wedge series of LED lamps from Superbrightleds.com.
The NEO3 size works well in many V70 XC 2000 applications.
Only catch is they are polarized thus if they don't work you will have to rotate them 180 degrees after reconnecting the power.
I have a 2001 volvo v70xc awd and I have a light out on my driver mirror when I press the approach light buttom on my remote keyless it does not light up. How do I change this bulb? [email protected]
Problems with using LEDs in ECC. One is that the light emitted is too bright - not diffused and so giving a blotchy effect. This can be countered if you are willing to take trouble - see below. Two is LED s work differently to incandescents so will not work with the pannel light dimmer switch.
I found a Jag forum in UK and a poster from New Zealand Oubadah 1995 XJ series. In his very informative and closely described post which is documented with excellent photos and is dated 07-03-2010; 01:21 AM see: www.jaguarforums.com/forum/xj-x300xjr-26/what-led-backlights-dimming-38712/ He explains that if you remove LED carefully from holder you will find a resistance and a diode, he shows clearly how to mark each LED for polarity and change value of resistance to get a better light. He illustrates how he set up a jig with the instrument pannel on a power supply and decade box, so he could experiment with different resistance values to find the best. He even illustrates the appearance of a changed LED alongside the stock incandescents. This guys posting is really an eye opener about how much time and trouble some people are willing to spend to get quality results!
