Hello all - like many parts of North America, Northern Alberta is in the middle of a cold snap which has ben going on for two weeks now. My 2002 XC70 has been OK, up until Friday. Leaving work, the car seemed to slip in 1st gear for about 1 city block. Even at 3000 rpm, the car was crawling. After a few minutes, all was well. I was on a really icy section in the strip mall where I work, so I put it down to that, but facing a family trip to Jasper Alberta to do some skiing (350 km away), I put a call in to my indy mechanic friend who replaced my exploded bevel gear in the spring. He reminded me that it was freaking cold, and that it was possible that the tranny software prevented full-speed operation in extreme cold temps. I was advised to check fluid before I left, but the manual does not refer to a transmission dipstick. The trip to Jasper was uneventful.
Saturday morning, we woke up to -38C Needless to say no skiing, but the same problem when I went out later that morning - no problem with reverse, but the car would crawl at about 3000 rpm for about two blocks - after a few minutes of that, everything was allright. Since I had a lot of time on my hands, I checked this forum, and found the dipstick location - after 1 hour of drive time, the trans fluid level was just up to full cold, and the fluid looked pretty brown (the previous owner had told me that he changed it sometime between 50K miles and when I bought it at 85K miles). Also, my new water pump seemed to be leaking a little bit. Sunday, it was just as cold and the same problem - 1st gear slippage for about two blocks, then no problems as the fluids warmed up.
I got a hold of another mechanic buddy of mine in Jasper who has a lot of Euro experience, fortunately his shop and hoist were open, and we had a look to see if I could make it home. Looked like the water pump issue was just from the vent hole, and since no one in town had 3309, he topped off with less than .5 liter of Dexron/Mercon - our logic being the wrong lubricant is likely better than none. We made it home with no transmission issues, no shifting problems (other than some weird climate control problems, but that's another subject).
Three questions -
1 - has anyone else experienced this type of problem - first gear slippage at extremely cold temperatures, and what might be the solution?
2 - I was taking a calculated risk with mixing in the Dexron/Mercon - a flush is coming soon - but could that cause future damage?
3 - asked tounge in cheek - where is the global warming part of climate change, and could we get some right now, especially in Northern Alberta? -38C is bloody cold!
I'm going to work tomorrow and will report on the condition - wondering if the top up has made any difference.
