So after browsing the web the last several days, I have found a way to build an HD turbo control valve that is identical to the iPd version for around $50 dollars. Here are the parts you need: 1) HD Solenoid Valve, 2) Bosch EV1 Connector, and 3) 1/8" vacuum connectors for solenoid valve. Throw in some teflon tape and some mounting tape and you are looking at the same HD TCV at a little over half price. Of course, you don't get the nifty mounting bracket, or a pre-assembled unit, but if you can work on your XC you can build this thing. You also need to find a rubber boot to cover connector. I have the parts coming in the mail and should have them this next week and will give a review! This is what a DIY version will look like in the end.
