A/T - AW55-50 Hard Shifts/Shift Flare
NO: 43-27
DATE: 1-22-2004
MODEL/YEAR:
MY 2001- S60, V70, V70 XC, XC90 2.5T
SUBJECT:
AW55-50 Adaptation Procedure
CHASSIS:
All
Reference:
For all other cars with the AW 55-50, please see TNN 43-20
THIS TNN SUPERCEDES THE PREVIOUS TNN 43-27 DATED 7-15-02. PLEASE UPDATE YOUR FILES. Updated for XC90 2.5T
DESCRIPTION:
The AW55-50 gearbox relies on adaptive data to properly adjust its
shift pressure. This data is collected and memorized by the TCM and then used to adjust
shift feel/quality. If the adaptation is not complete, it may result in:
Shift Flare: Engine RPM increases during a
shift. This symptom often feels like the car has temporarily lost drive or the transmission is slipping. It is usually the 2-3 upshift that flares the most.
- Harsh Down Shifts: Harshness felt during a coast-down
shift (zero throttle downshift).
- Harsh Garage Shifts: Harshness when shifting P-D, N-D, P-R, or N-R while at a standstill.
- Harsh Neutral Control Engagement/Disengagement: After coming to a complete stop in Drive, with your foot on the brake the TCM waits 2 seconds and then disengages drive to reduce emissions and minimize idle vibrations. This disengagement is normally smooth and isn't felt by the driver. If adaptation is not complete then a "thud" can be felt in the car 2 seconds after coming to a complete stop. When the brake pedal is released, the re-engagement of Drive should be relatively smooth. A harsh re-engagement can be felt if the adaptation is not complete. Neutral Control is present on all 2001 MY S60s and V70s. It is also present on non-turbo 2002 S60s and V70s produced before January 2002.
The TCM can sometimes take many miles to fully adapt. To assist in the process, a function called "Control Module Adaptation" has been included in VADIS. This mode is useful when the car is new, the gearbox, valve body or TCM have been replaced, or anytime you want to be sure that the transmission is fully adapted. The picture shows where to find the function. There is no need to "Reset the adaptation to zero", unless a piece of hardware, such as the valve body or gearbox has been replaced.
ADAPTATION MODE:
When you follow the procedure, you will first be directed to check which software version is in the TCM. This is because some cars need to be loaded with the latest software for the function to work (Please refer to
TNN 43-24). Once you have checked the software, you will be directed to the procedure. After reading through the procedure and using VADIS to put the car into Adaptation Mode, you can begin the adaptive test drive.
When the transmission oil reaches 65̊Celsius (150̊F.) a text message will appear in the DIM to confirm that you are in Adaptation Mode. It will remain in this mode until the car is shut off. If the transmission oil temperature exceeds 110̊Celsius (230̊F.), Adaptation Mode will be suspended and the text message will disappear until the temperature comes down.
The transmission does not adapt while in Geartronic or Winter mode; do not use those modes at any point in this procedure. While the car is in Adaptation Mode the orange triangle in the center of the instrument cluster (DIM) will flash just after a "perfect
shift". A perfect
shift is one where the TCM has reached its adaptation target for that particular
shift.
To adapt the Upshifts:
1. Use 'D' range. The TCM does not adapt while in Geartronic. From a standstill, accelerate lightly (about 1400 RPM) up to 4th gear. Keep the throttle steady during the acceleration. Come to a stop and repeat this maneuver until the orange triangle flashes after each of the three shifts. It may take several accelerations to complete this. You will not reach 5th gear at this small throttle opening.
2. Perform another steady acceleration, all the way up to 5th gear. This time use a higher throttle position (about 1800 RPM). Repeat the maneuver until you see the orange triangle flash after each of the four shifts. Remember to keep the throttle steady.
3. Again accelerate up to 5th gear from a standstill; this time at an even high throttle opening (about 2500 RPM). Repeat the maneuver until you see the orange triangle flash after each of the four shifts. Remember to keep the throttle steady.
NOTE: The TCM is continuously adapting. Not every
shift will be a "perfect
shift". For example, you will not see the triangle flash after every 1-2
shift. You only need to see it flash once for the 1-2
shift at each throttle opening to know that the adaptation has reached its target.
To adapt the Downshifts:
1. Use 'D' range. The TCM does not adapt in Geartronic. Drive along at about 45 MPH in 5th gear. Release the throttle and gently brake until you are at a standstill. Use very light pressure on the brake pedal.
2. Repeat this maneuver until the orange triangle flashes after each of the four downshifts. It will take several decelerations to adapt all of the shifts. If you are having difficulty, increase or decrease the pedal pressure you are using.
shift". For example, you will not see the triangle flash after every 3-2
shift. You only need to see it flash once for the 3-2
shift during this maneuver to know that it has reached its target.
To adapt the Garage Shifts:
1. With the engine idling and your foot on the brake,
shift to 'N'. Wait 5 seconds;
shift to 'R'. Wait 5 seconds and
shift back to 'N'. The adaptation has reached its target when the orange triangle flashes after you
shift to 'R'. If the triangle flashes once, you do not need to see it every time after that. This is because the TCM is continuously adapting.
2. With the engine idling and your foot on the brake,
shift to 'D'. Wait 5 seconds and
shift to 'D'. If the triangle flashes once, you do not need to see it every time after that. This is because the TCM is continuously adapting.
To adapt the Neutral Control:
NOTE: This only applies to certain cars. They are listed in the "Description" section of this document.
1. Drive along slowly (about 5 MPH) in 'D' range. Gently bring the car to a complete stop. Repeat this maneuver until the orange triangle flashes a few seconds after you stop the vehicle. This tells you that the Neutral Control engagement is adapted.
shift to 'D' range. Wait about 25 seconds and you will see the orange triangle flash, telling you it is ready to adapt. After it has flashed, release the brake pedal and allow the car to crawl forward. Repeat this maneuver until the triangle flashes just after releasing the brake pedal. This tells you that the Neutral Control disengagement is adapted.
shift". For example, you will not see the triangle flash every time you release the brake pedal. You only need to see it flash once to know that the neutral control adaptation has reached its target.
Once you have adapted the Upshifts, Downshifts, Garage Shifts and Neutral Control, the procedure is complete. When the ignition is switched off, the TCM automatically exits adaptation mode.
