I have a 2004 XC70 with 218,000 Miles on it. I've done my best to treat this vehicle well, with timely maintenance / oil changes (always synthetic), and always Volvo / OEM parts for repairs.
About a year ago, I started to notice a slight whine coming from the turbo (I assume). It tended to be very mild and go away once the car heated up. Barely audible. I just filed away the notion that I would at some point need to replace the turbo, but didn't think much more about it.
On Friday of last week I noticed the car misfiring slightly while on my way home from work. I pulled the code and it showed a P0302, indicating a misfire on cylinder 2. I assumed it was the ignition coil since I had replaced the plugs about 2 years ago. I was just a mile from an auto parts store, so I headed there, purchased an ignition coil, and put it in the car in their parking lot, noticing what looked like a fair amount of oil in the spark plug well.
I got back in the car and headed home expecting everything to be resolved, but there was no change. My house was only a mile of two from the auto parts store, so I limped it home, the misfire becoming constant / worse, meaning the cylinder wasn't firing at all by the time I got home.
This weekend I pulled all the ignition coil, cleaned the spark plug well for cylinder 2 of oil, which there was a lot of, then pulled the spark plug for inspection and replacement.
I pulled the spark plug and was mortified to see that the entire porcelain and copper end was completely gone and the threads and plug were covered in oil.
Photo of Spark Plug
Attachment 8477
Linked Version
https://i.imgur.com/hke7nJL.jpg
I checked the forums for ideas on what to do, and it seemed like the oil could potentially be leaking from the oil filler cap due to an old gasket. I had replaced this gasket a couple of years ago, but I guess it might be time again?
I manually cranked the engine over to inspect the cylinder and attempt to clean it. The cylinder head looked a little spotty, almost dirty, but not scored, from what I could tell.
I then Macgyvered a shop vac / tube situation to stick down into the cylinder to attempt to suck out the spark plug bits, if their were any. I stayed at it for what seemed like an eternity, never finding that the vac sucked anything up.
I blew compressed air into the cylinder, then fired the engine up with no spark plug to try to make sure that if there were any bits in the cylinder, they were blown out.
I put in a new plug, started her up and listened for anything out of the ordinary. Everything sounded fine. I cleared the codes and considered everything sorted, crisis averted.
I took a test drive on Saturday a couple miles to the Grocery store, and the car operated as it should but never got above 15 miles per hour around town.
Today I took the car to work (30 min highway) , and pretty soon after getting on the road the Turbo whine came on with a vengeance. Much louder than ever before.
After driving on the highway for at least 20 min, the car started to rumble much worse than before, a cloud of smoke was exiting out the tailpipe, accompanied by a burning smell, and an almost complete loss of power. I'm talking about an equivalent amount of power of a moped engine trying to push her.
At this point I was at my work exit and was able to basically coast in neutral the entire way to work (only about a 1/4 mile from this point).
I'm sitting at work without a clue as to what to do. It seems to me that the car was fine until it heated up. Should I attempt to drive it home? I just ran the engine with the car parked, and it sounds totally fine. It's not until attempting to drive does the whine come back, but obviously something serious is wrong.
I'm also now pulling codes:
P0333
P2178
I'm hoping someone here can explain to me how this could all be related, and what needs to be done. I'm thinking the problem is 100% that the Turbo needs to be replaced, but how did that foul / destroy a spark plug. Why did the engine whine increase drastically after replacing spark plug? Could the spark plug tip have shot out through turbo and put the nail in the coffin with that?
Does anyone know if the turbo can be replaced without having to take the angle gear / propeller shaft and passenger drive shaft off? I did an angle gear replacement 2 winters ago, and it was absolutely brutal. I don't think I want to have to deal with taking the angle gear off again in order to do turbo, but I'm not really in a position to pay someone $2000 to swap the turbo out.
Any insight would greatly be apprechiated.
EDIT: I just checked the oil level, which should be fine since I had it changed a week ago, and it was barely a quarter inch from the bottom of the dip stick. I guess that means driving it anywhere is a complete no go.
