Results 1 to 10 of 13
    Dec 2002
    upstate NY, USA
    Question rear wiper blade replacement
    Hello folks
    Sorry it has been so long since I have been on the forum ! Happy to report my '04 now has 21k wonderful miles on it, and looking forward to many more !
    We just put new wipers on my car, SilBlade which are all silicone with a PTFE coating, and 5 yr warranty. So far so good.
    The problem we have is figuring out how to change the back one. The owners manual was not real clear, and don't want to break anything.
    Happy New Year to you all, and safe winter motoring !
    xcrubygal
    '04 Ruby, sand, prem pkg, tour pkg, xenon, DST, xenia wheels, OSD
    Jan 2003
    Sherbrooke, Québec
    Lightbulb Pull and push
    Removing the rear wiper blade is just a matter of pulling it out, as show in the owner's manual. Seems to be a special kind of blade though... The only place I found one is at my dealer.
    Raynald
    Former owner of a 2001 V70XC Nautic Blue
    Sept 2003 - April 2007
    « Sold » with 167,427 km on the clock, to my stepson...
    Still proudly showing volvoXC.com Sticker for posterity !!!
    Art's Avatar
    Oct 2001
    Red Deer, AB., Canada
    Default Poor design IMO.
    The plastic tab that holds the rear wiper arm in place just shattered in the frigid temperatures that we’ve been enduring here for the past week. A new replacement arm will cost $53.00 Cdn. I really think that Volvo should utilize a universal hook similar to the design of the front wiper arms.
    Nov 2004
    Default wiper blade
    a standard 17" micro edge bosch blade worked fine... remove all of the plastic clips and it will snap perfectly into the wiper arm...
    Aug 2002
    Cascais, Portugal
    Default bosch micro edge
    Quote Originally Posted by sandre
    The only problem I have with those is, that they always miss a spot in the center of the window..
    2008 V70 2.4 Classic Sports Edition
    Art's Avatar
    Oct 2001
    Default Broken Clip.
    Quote Originally Posted by Sandre
    Sandre,
    Could you possibly elaborate more on how your Bosch blade snaps into the rear wiper arm? I see on their website that the replacement blade comes with a pre-installed adaptor (U1). With the stock wiper length being 16", are there any clearance issues with the 17" Bosch blade? Thanks.
    I’ve also attached a pic of the broken clip that secures the blade to the rear wiper arm. Like Raynald, I’ve also been unable to find a blade that fits the XC’s rear wiper arm other than at the dealer.
    Nov 2004
    Default wiper
    if you completely remove the plastic clip that is part of the new wiper blade you will be left with a thin steel cross piece,,, the size of a med size nail... this should just clip into the wiper arm... when the blade is in the middle of its stroke it comes slightly off the glass...it was raining today, i had no problem with it missing any part of the glass ( with the exeption of fore mentioned tdc which you really don't notice looking through the rear view mirror). hope this helps, steve.... art i'm sorry,,, i didn't get a good look at your arm until after i posted this ... from the picture it looks like the clip is broken and i don't recall seeing a replacement with the new blade... i would check for you but i through the clips and packaging away... might be a dealer item... good luck.
    Art's Avatar
    Oct 2001
    Thanks for the reply Steve. I felt a need to explore all of my options before pushing off to the dealer for a replacement arm. Much appreciated.
    Apr 2014
    Newington, CT
    Default Stock Wiper Blade Replacement for 2004 Volvo XC70 Rear Wiper
    I found a rear wiper blade at the local auto parts store that fit with a little modification. The Trico ExactFit RearBlade 16-B. The blade receptacle is made of plastic and is easily modified to fit the Volvo wiper arm. I used a dremel tool, and the modification took me only 5 minutes. You could used a round file, but the Dremel made short work of the mod. Two parts need removal - two little guide bumps/nubs in the opening where the wiper arm attaches, and the same opening needs to be lengthened by about 1 cm at its curved end. The blade fits perfectly in the wiper arm assembly and even secures with a satisfying click.
    and this is easier than going to your dealer and buying the correct blade?
