    Sep 2011
    san francisco, ca
    Default 2005 brake issues
    Our 2005 XC (210k miles) started to having a front end wobble under light to medium braking and the front right rotor was showing signs of chatter so I replaced the pads, rotors and calipers. The rear brake pads were at about 40% so I went ahead and did the rear pads and rotors too. This car has always had a softer pedal than our other cars but it always stopped fine, until the wobble started. When I bled the brakes though I was getting pedal creep, so I bled them again. Same thing. There was no air but I bled them a third time and made sure I flushed all of the old fluid. Still had the pedal creep. Then I noticed that if I pumped the brakes up I could hear a slight drumming noise coming from the master cylinder. I blocked off the ports to the master and was still getting the creep. I just got done bench bleeding and installing a new master and bled the brakes for a fourth time. It fixed the pedal creep when the car is not running but once it’s running the creep is back and the pedal is pretty soft. I’m pretty sure I’ve installed the anti-rattle clips correctly. What else could be causing this? The other thing is the the vacuum pump is coming on when I press on the pedal but I was assuming that’s because the car was just idling and hadn’t created enough manifold vacuum.
    Are you certain that the caliper spring is installed correctly?
    Soft pedal following pad replacement is a common occurrence. Most likely cause is the caliper sprig being installed over the ears, and not under. If the spring was easy to install, it wasnít done correctly.
    Give this a readÖ
    https://sites.google.com/view/howard...h.w4lpdxakno88
    Sep 2011
    san francisco, ca
    The springs are installed just like the photo in the article. Like I said the pedal doesnít go down when the car is not running even while applying quite a bit of pressure only when the car is running will it creep down. Could this be a symptom of a failing ABS module? There is no warning light
