Results 1 to 8 of 8
    Nov 2014
    USA
    Default Coolant leak as car cools down
    I've got a coolant leak in my 2003 XC70, and the odd thing about it, at least to me, is that the leak doesn't appear while the car is running and at full temperature/pressure. The leak appears about 2.5 hours after the car is parked. It's dripping on the passenger's side.
    For example, I drove the car for 20 minutes today mostly at highway speeds. Parked 10-15 minutes. No leak. Drove another 20 minutes on highway and stopped at a pharmacy for about 10 minutes. Checked for leaks. No leak. Drove home. 2.5 hours after the car was parked, it's dripping, leaving a small wet spot on the driveway.
    Then once the car is pretty completely cooled down (four hours), the leak stops.
    Any ideas what would cause this kind of leak?
    Have you noticed if the level of the coolant in the reservoir is low? Have you had to add more coolant yet?
    You're certain that it's coolant?
    Nov 2014
    USA
    Yes, I have had to add more coolant twice, but not a lot. I got an alert on the instrument cluster.
    Nov 2014
    USA
    Yes. I've been working on my own cars since the 1980s, but mostly GM. Not a Volvo expert.
    Well, if you've had to add coolant twice, then you should be able to find the crusty deposit that a slight leak will leave. May have to go hunting with a mirror and a good light.
    Most cars leak under pressure. After cooldown, pressure is reduced.
    Immediately after shutdown, temperatures (and pressures) tend to peak.
    I wonder if it leaks only under very high temp, but it doesn't trickle out for a while after that...
    Jul 2010
    Rugby UK
    This could be a gentle warning the head gasket is on the way out. I had several isolated bouts of that atwo years ago. This fall I noticed on the induction side of the block small crystaline structures (cold engine) after a frosty night. I think it was fine coolant spray reacting with the aluminum block. Taking the head off on a RHD car is a pain there are far more obstructions underneath on RHD layout. I am still working out how to undoo two of the heat shield bolts.
    Nov 2014
    USA
    I was having a hard time pinpointing the leak, so I took it to my mechanic, whom I trust.
    Solution: Leaking water pump.
