Well, low compression on that cylinder would explain the misfire. The head has to come off to see what’s going on. Hopefully it’s in the head - damaged valve, etc. and not in the block - like a damaged piston.
Do you have a bore scope? Would love to know what a camera sees in that bore.
Not sure what units you’re reading on the compression gauge, but the LPT engine is about 9.0:1 compression, so you should see at least 160 or so PSI. I know that more than 9x14.7 but it’s about how much you see on a healthy 9:1 engine.
Consistency across readings is the real test and a low cylinder is a cause for concern.
