Results 1 to 10 of 12
    Mar 2019
    Default I think I need to bleed my brakes
    Pedal feels spongy, reservoir still full.
    I guess bleeding is step one ( hopefully of one ) towards diagnosis.
    I have seen plenty of generic how to bleed your brakes vids on you tube.
    Anything specific for an 01 v70 xc ? Any european "eccentricities" I need to consider ?
    Ben
    Quote Originally Posted by BenF View Post
    You bleed brakes to get air out - the question is - How did the air get in? If it's never been low enough, air has not infiltrated the system.
    So yes bleeding the brakes is a good first step, but probably not the only step.
    Have you been changing the brake fluid every few years? If not you may have a master cylinder going bad, or sometimes a sticking caliper (not sliding) can make the pedal softer (but it's rare with single piston calipers)
    Did you recently replace your pads?
    Did you put the caliper spring on correctly?
    Is the caliper spring missing?
    Brake fluid slowly goes bad over time, by absorbing moisture. Because of the high pressure in a hydraulic fluid, water boils at a low temp. The moisture in the brake fluid
    boils and forms pockets of gas which become compressible...this makes the brake response go soft. 40,000 mi. is a recommended interval for flushing brake lines.
    Sep 2020
    This must explain what happened to my uncle's car running at 50k miles with a soft brake pedal.
    Mar 2019
    I have never touched the brake system, I don't know when if ever it has been bled / fluid changed. I agree that it maybe the master cylinder or something else, but it seems to me that step one is to bleed / replace the fluid. If the problem persists then I will start further investigation.
    When you bleed it, take good look at your front caliper springs. If they aren’t installed correctly, or have broken, you will have a soft pedal.
    In fact, post a picture of those springs here, and let me take a look. There are dozens of threads on P2 Volvos with soft brakes following DIY brake work, and it’s all from incorrect spring installation.
    I’ve had a caliper spring fail/break. Instant soft pedal.
    It could be your master starting to fail.
    I don’t expect much improvement from a brake flush to be honest. Brake fluid absorbs water over time, and causes all sorts of problems, but old brake fluid works fine from a hydraulic perspective, it doesn’t suddenly become compressible and cause a soft pedal.
    Aug 2020
    Seattle-ish
    I'm coughing to the left in my sleeve (in embarassment) on one point. Mr. Tomcat always has sage advice. I did a pad change a few weeks ago as the sem-metallic Jurid pads were just eating the rotors. I had the rotors turned and put in ceramic pads, and the pedal is a *little* softer and the braking not as firm. But in the process, I lost the LF spring in some ivy on the side of the driveway and after 1/2 hour of hunting for it, I said, "I'll just find it when the RoundUp kicks in next week." Which I did. It's still in the glove compartment waiting for the tire swap in a few weeks to go in. Despite a lot of years (decades) of wrenching, I assumed it was a squeal device and wouldn't affect feel like that. Live and learn. Thanks for teaching, Astro.
    However, I will comment constructively on this:
    agree 100%. And unless you are an experienced wrench, I don't advocate doing a brake flush vs. a better way that exists. Siphon out your fluid reservoir, clean it the best you can (if needed), then put in fresh fluid. This alone will drop your fluid water content by 1/2. The reservoir fluid will mix with the system fluid over the course of time as the MC piston activates. It won't be instant, but it will get into a homogenous mixture after enough driving. It's been tested and shown to work. (If you doubt this, look at a diagram of how an MC piston works and you see it will). If you need to see it, this tedious video will walk you through it:
    https://www.youtube.com/watch?v=Xk2zGvKfrhc
    The reason this is good is that you can do it cheaply two, three times and drop your fluid content down to near zero and never risk introducing more air into the system via bleeding. Bleed screws are finicky and being slightly loose with the wrench on them can get air sucked back in via the threads on them VERY easily. Unless you suspect a bad bleed job was done and there's air in the system, a few drain/fills on the reservoir will get you right. I live in the PNW (Seattle area) and maintain a lot of cars and motorcycles. Just dumping the reservoir annually and refilling is all it takes to keep everything 5x5.
    Mar 2019
    Thanks all interesting stuff, so I had a go at this last night and can report some good progress, the travel has reduced and a short test drive felt better, I will monitor it over the next few days ( does anyone else find themselves so hyper vigilant on a test drive that its hard to be objective ).
    Anyway, the fluid in the reservoir was a horrible black color and some rusty looking crap and big air bubbles came out of the calipers. That said I might try again as it was a bit of a comedy of errors.
    1. I made tube in bottle type device and had the tube going in a really tight fit to the lid and neglected to make a breather hole, so when I took it off the first one I made a nice brake fluid fountain!
    2. My floor jack leaks like ****
    3. The back drivers side wheel did not want to come off, I resorted to driving around my neighborhood with really loose lugnuts to break it loose.
    4. So I forgot about the springs because I was racing the dark by the time I got the front.
    But to astro's point. The brake pedal didn't suddenly become spongy, it probably always was a bit and in the last couple of weeks just got to where I had the occasional moments doubt as to whether or not I was going to stop. Basically it was a very gradual process of going soft.
    Cumbria, UK. Maine USA.
    Refreshing to see someone who actually thought about it and decided on a method to solve this rather common problem rather than brute force and destructive remedies.
    Current Junk: Couple of worthless rusty old clapped out Volvo bricks, XC70's 02, 04 & Countless P.O.S's, Rust buckets, Junk cars,( 50W Oily cesspool Sludge) Stolen and other assorted rubbish cars, 1928 Jed Clampett Tourer, (8 hole cast iron lump, original rust and decay, 40W Straight Bacon Grease),
