Results 1 to 6 of 6
    Mar 2013
    Anchorage, Alaska
    Default Check Engine Light With Not Working Temperature Gauge
    Hello folks, hope you all are managing the mask era good enough!
    Out of the blue, my check engine light came on, with no message in the message window. Looking around on the gauges, I realized the temperature gauge is not working; the pin is way down to the left. What might this be?
    Mar 2013
    Anchorage, Alaska
    By the way, this morning, I drove it from one spot to another, just about 30 feet drive and the auxiliary fan came on.
    Maybe no temp sensor signal defaults to full fan - what does your VIDA say?
    Mar 2013
    Anchorage, Alaska
    https://www.dtcdecode.com/Volvo/ECM-2000
    Mar 2013
    Anchorage, Alaska
    I had replaced the "Water Temperature Sender" back in September 2019.
    If you click on the ecm2000 code you should be able to navigate to a screen like this with suggested cures -
    And there is a graph of expected resistance reading for the sensor at various temps listed under "product specification/specifications/electrical/2engine/284 control systems/specifications/component specifications"
