Results 1 to 2 of 2
    Mar 2012
    Northern Lower Michigan, USA
    Default Hood will not latch
    2004 XC70. My hood would not latch after opening, and the release handle didn't return to "rest" Temp is just under 32F/0C. I started the car, turned the heat to full-hot, fan on full, walk away. I had already pulled the release handle gently and slid my hand off it to allow it to snap back. 25 minutes later, I repeated this last action and then dropped the hood. The catches accepted the hood as locked.
    Might want to spray down the latch mechanism real well with WD40 or similar penetrating oil; you could have some crud buildup. Lube the points on the latch which pivot and move the release handle back and forth several times to see if that helps!
