2008 XC70 going into limp mode and various electrical glitches
Hi guys!
Posting this for a friend who just bought a new to him 2008 XC60 3.2l
2008 XC70 NA 3.2L AWD. 218,000 kms.
This problem started happening approx 1 month ago.
About every day I drive the car, the following cycle occurs: I drive along like normal, and after a few 90 degree left turns I have to make on my work commute, I notice my speedometer flashing up and down (4 or 5 times) between 0kph and whatever speed the car is travelling at, during the left turn. Usually one left turn later, after the speedometer waving up and down, I get a few driver messages all at once - Brake Failure Stop Safely, DTSC failure service required, and Parking Brake service required. As soon as this happens I experience about a 40% drop in power, especially noticeable when starting off from a stop.
A few other things of note:
- The gear indicator on the instrument cluster shows a dash (-) instead of D for drive, etc.
- When shutting the engine off, occasionally the 'start' button requires multiple presses before it will shut down.
- After the engine turns off, occasionally the key itself requires multiple presses into the ignition before it will release the key.
-this also happened on the highway a few times where the car completely stalled then restarted again while it was coasting, if given too much gas it would stall out
- I recently replaced both front sway bar links because the original ones had broken off from the top end where they were bolted to the hub assembly. The passenger side one was fully broken off and not connected by any material at the top, driver's side was still 50% attached at the top. One theory of mine is that the loose link had dragged a speed sensor wire out of its stable connection but upon inspection seems intact.
-The battery was replaced as it had loose posts and was leaking
- The negative battery cable is partly corroded and I am awaiting a replacement from Amazon.
- This is the only electrical issue I have. Everything inside the car works - stereo, A/C, windows, etc.
I have personally read the codes with VIDA and there are WAY to many codes for me to make sense of; I will try and find the screenshot I have of all the codes and add it to this post tomorrow. I did take a look at this XC before he bought it and I can confirm none of these codes were pre-existing when he bought it.
If you have had a similar issue with your p3 xc70 I'd be interested to know how you fixed it or what you determined to be the cause. I suspect there is a bad speed sensor somewhere or a short causing the chain reaction of symptoms but any insight would be greatly appreciated.
Thanks a ton!
2006 XC70 360,000KM, Hilton Tune, BadSwede Lift, Big Burly tires, totalled.
