2006 XC70 transmission failure
Hi All
Looking for opinions before I tear into it.
2006 XC70 lost forward and reverse motion.
It happened while driving, short metallic sounding clunk, engine revved up and that was it.
So far I checked the following:
- transmission fluid level is fine and clean. (has been drained and filled once a year).
- VIDA does not show any TCM codes.
- with the car on a lift. Checked the front axles, both are engaged and fine. Spinning one wheel by hand makes the other one spin in the opposite direction indicating the differential is fine.
- the prop shaft will also spin if you hold one front wheel steady and turn the other by hand.
While the car is in D, R or manual mode. There is no power being transferred to the wheels. It won't move.
Has anyone had similar issues ? The car has 150k miles on the clock.
Thanks in advance.
My fleet: '04 V70R, '06XC70, '86 760T, '90 760T
