Started with this car and swapped the motor over due to an oil issue by previous owner. Motor came with the car and was from a salvage yard in the southern MA area and had 125K miles. Car itself has around 180K. I swapped the motor over and while it was out, I replaced:
New Sachs struts, strut bearings and mounts
Torque converter
Transmission valve body kit
New front rotors and pads
New swaybar links
New control arm bushings
New inner and outer tie rods
New ball joints
New bellows for the steering rack
Sub frame bushing inserts
Top motor mount
CV joint for the driveshaft to the rear
New filter for the Haldex unit
New waterpump, belt, tensioner
New timing belt and tensioner
Output seals replaced in the angle gear
New battery
Have new rear rotors that were not installed
Parts ordered came from FCP and are OEM supplier parts, not aftermarket knockoff. I can dig around and produce receipts as proof of purchase and I've also included my project link.
I'm sure there's more that I'm forgetting.
http://www.volvoxc.com/forums/showth...0-car-purchase
So the car starts and runs fine. Transmission needs to be put into adaptive mode to relearn shift patterns. I have the VADIS module, but was unable to get the software ironed out since I'm not an IT guy and that right about the time that our need for the car changed and it started to sit around and then my son bought a new Audi.
Asking $1400 for the car and I'm losing money, but it needs to go since there's little room and we are now at 5 cars with winter coming. The home owners association hasn't said anything, but it's only a matter of time....
Car is located in Salem MA and I can be reached at dtmackey (at) gmail (dot) com
I can upload pics over the weekend.
D-
