Results 1 to 6 of 6
    Aug 2018
    NH
    Default Timing belt question
    Hi all,
    I just completed allot of work on my 2004 XC70 AWD. I replaced the Head gasket and all timing components. I noticed the my timing belt tensioner moves back and forth while the engine is running. Is this normal? Also, does anyone know what the normal engine temp is when the engine has been running for awhile?
    Thanks,
    Frank
    Mar 2005
    Pacific Northwest
    Thermostat opens around 180-190F and I've seen ATF (heat matches coolant via heat exchanger) around 90C (in VIDA) after warm up so I would guess around 190-195F+
    Don't know about TB tensioner movement. Usually have the cover back on and can't see after the TB job.
    Timing belt tensioner is intended to move with heat/cool cycle. Tension must be set at 20C. Details in the resources section.
    Aug 2018
    NH
    Thanks for the replies, I really appreciate the help. I realize the tensioner is supposed to move based on heat but mine throttles back and forth like a clock ticking counter clock-wise from the 12 o'clock position to the 11 o'clock position then back to the 12 position. I also made sure I tensioned the belt correctly upon installation. Everything seems to be running fine, I just noticed the movement and was curious. Like howardc64 said I normally have the cover back on and never seen one until now. I just want to make sure im not setting up my new components to fail prematurely. Thanks again for the help.
    Ah, I see...
    I've not run the engine without the accessories in place, so I haven't watched the timing belt, or tensioner while running. It's reasonable to assume that the spring will allow it to move while running. Serpentine belt tensioners do that while running.
    Mar 2005
    Pacific Northwest
    Quote Originally Posted by gtacs View Post
    Whenever rotating the crank by hand, it required uneven rotational force due to compression stroke. There might be uneven rotational force required to turn the cams lobes against the valve stem as well but probably much less. Not sure what are the variation of rotational forces while idling but if exist and large enough to overcome the tensioner spring force, I'd imagine we'd see what you observe. Can't confirm this is what in fact happens but thought could be a potential explanation. I guess the confirmation is to see another car. Not too hard to pull the serp belt + timing cover to see the TB tensioner in action.
