Slow down, pardner...
It slips. Got it.
low fluid and/or poor fluid condition can cause a slip, so before you start shopping for a new transmission...
Check the fluid level. Minimum 20 minutes of driving, find a dead-level spot, leave it idling in park and pull the dipstick, wipe it clean on a white paper towel. re-insert and check the level. Check the paper towel and dipstick for color/condition.
If the level is off, correct it.
Personally, I would do a fluid cooler line exchange (the Gibbons method), easily done, get the kit from IPD and buy a case of Toyota T-IV at your local Toyota dealer. (Mobil 3309 on Amazon is another good bet).
With clean fluid at the proper level, if you've still got slipping, then, and not before, it's time to consider mechanical repair...
