Results 1 to 2 of 2
    Aug 2018
    Madison NJ
    Default 2008 XC70 AC drain clog
    I am pretty sure the AC drain is clogged, the front passenger carpet is wet and water starts misting from the registers after about 20 minutes. Can I unclog the the drain hose, or is it a difficult repair? Thanks for your input.
    If you know how to safely raise the car onto jack stands in the front, crawl under with a few drill bits, 1/8" - 1/4", and a flexible probe such as a tie wrap.. Locate the AC drain tube. Carefully extract any debris built up in the drain tube. If you have a vacuum pump, or a makeshift attachment to vacuum cleaner, suction also helps.
