Seals get popped out by excess crankcase pressure. Massive leaks result. Replacing the seals is pointless as long as the pressure problem still exists.
When you had the pan off, did you clean the PCV system? Didn't we discuss that in an earlier thread?
Crank seal is relatively simple: remove the timing belt, remove the balancer, pull the crank pulley. You'll need a gear puller for the pulley. You'll need a seal installer - which I made from a 3" piece of PVC pipe. THe OD of the pipe matched the seal size and served as a driver.
The ongoing saga here is frustrating, I get that.
Two key questions: did you ever get a known good oil pressure gauge on this engine to see what the actual pressure is? Did you ever get the PCV system sorted?
