When I drained the ATF to do the VB repair, the fluid looked bright and red (no strawberry milkshake). I replaced this same fluid after completing the repair and topped up with another 400ml for all the additional ATF which had drained from the hoses and old VB. Did a few test drives with the new VB, got the ATF up to 80C, checked the level and found it to be overfilled. I drained 500ml from the drain plug. I looked at this fluid and this was THE FIRST TIME I found it to be pink and milky. Did a Gibbons flush of 12 qts. and the old fluid looked like a strawberry milkshake.
I have two possible explanations. I damaged the radiator during the repair or water got into the radiator/trans during the repair. I did not have the radiator ports completely plugged nor the trans housing sealed airtight while working. The car was sitting for a week with rain, snow, large temp swings so maybe there was condensation? Of course I'm gonna monitor the situation, make sure I'm not losing coolant. With the new flush, the shifting is noticeably smoother than the two test runs with the pink milkshake so if the ATF becomes contaminated again I expect I'll notice the rougher shifts. Still, once the ATF has been contaminated the damage may already be done and I think I noted this in a previous post. This is why I flushed the fluid ASAP. Keeping my fingers crossed and watching the coolant level.
This car doesn't see a lot of use and mostly gets driven around town. If I need to keep it under 55mph to avoid Limp mode, it can be done. The dealbreaker was the slipping trans when the fluid got warm. So far, this condition seems to have been corrected with the new VB. I've still got more testing to do and options to explore. I just added 150ml ATF so need to confirm level is correct at 80C. When driving at 55+ mph, I can possibly use 4th in Geartronic or cruise control. I still have not done the adaptations for the new VB. I don't think I have the latest version of the trans software.
Thanks everyone for the guidance and support!
