Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    List is correct unfortunately just at high retail!
    He forgot one thing a throttle gasket.
    Now is the time to clean your throttle body. When everything is apart it's right there, staring at you so take it off AND CLEAN IT (carefully).
    Add a new set of spark plugs now and you won't believe how much better and smoother the XC will run and how much more throttle response you will have after cleaning.
    Jul 2016
    Pacific NW
    Whelp... there goes my hopes to get this done for less than $200.
    Anybody have good luck with the iPD breather hose instead of the OEM?
    Car was running real smooth in the desert this summer, was getting 24+mpg on a road trip through Utah. Definitely notice the symptoms more during cold weather so I'm trying to take care of this soon.
    Parts will cost you more than $200 even at wholesale, then it's 4-5 hours in labor!
    It's a $500 to $800 job when done at a shop. It's a BIG job!
    It's a big, but very important job and MUST be done at around 100K (+or-) miles to 95% of these engines
    May 2015
    San Diego, CA
    My plugs were relatively new, but I did clean the throttle body. You are right, the results were amazing.
    Oct 2017
    Lancaster, PA
    I just got my PVC system serviced myself: Many people may not agree with what I say: Every things can be clean and reused, except the tiny plastic hose attack to the banjo bolt, it brittle and easy to break I replace it with a small rubber hose of same size, clean the banjo bolt hole and the nipples used the wire; I clean all the hose, just let them soak in some cleaning solution, then use air hose to blow the gunky out, for the breather box use a metal blade clean out all the openings (nipples), pour some gasoline inside shake it up and dump the sludge out, repeat couple time, the box is just hollow inside, I even repair all the ring clamps and reused them, didn't cost me a penny to have this service done.
    Feb 2011
    Windy Manitoba
    Quote Originally Posted by sjonnie View Post
    Your mechanic must have an overdue boat payment.
    Not any more
  7. #17
    Dec 2004
    Connecticut, US
    Thang, I did the same except for the clamp part.
    DYZ
    2005 Volvo XC70, Ash Gold, 210K miles
