++1
Originally Posted by
howardc64
I'd suggest you get diagnostics done with a Volvo factory diag tool (VIDA/DiCE). OBD tool just give basic diags and Midas won't have the Volvo tool or experience. Volvo tool likely can tell you more in depth the reason for failure and an experienced Volvo tech might have more knowledge with detailed error code (it will be stored even if currently no problem)
Common ETM problems were with 01s. 02+ have the newer Bosch ETM with much lower failure rate. Lots of things can cause limp home mode (safe mode) so best to be sure before throwing $1200.
My suggestion is to go to a Volvo indy and get another option. Probably cost $100 for diagnoses.
