I have a 2003 XC70 with a fuel-fill problem that's been driving me crazy. To fill it, I have to stand at the pump for over 10 minutes, holding the fill valve the whole time, with gas trickling into the fill neck. I can hear air escaping back up the neck, and if I go too fast, it will foam up and shut off the pump. It's been this way since I bought it from my sister.
I checked the hoses near the fuel inlet for spiders. That's not it. When I gave up, I mentioned it when I took it to a well-known and reputable Volvo specialist in town for another issue, and they took a look at it. They also checked for spiders and did a pressure test. They said they thought it was a stuck rollover valve and that they would have to drop the gas tank to fix it.
I recently had them replace the oil/air separator, and they were supposed to fix the refueling problem. On Friday night, it was almost out of gas, so I went to fill it up, and to my frustration, the problem is exactly the same as it was before I paid to have it fixed. I won't be able to talk to the mechanic until after the July 4th holiday is over. They were very busy when I picked up the car, so I didn't have a chance to talk to the mechanic about what he'd found.
I'm completely at my wit's end with this. What the hell could be wrong with this thing?
