Don't cut wires...if those posters are wrong, and they often are, then you're setting yourself up for more headaches.
The alarm is more than just the siren module, but it's likely the module that's draining your battery. Search the posts here on how to remove it and just unplug it and remove it. Then see if your battery dies...I suspect that will fix it. You'll still have the alarm service message, but at least your battery won't go dead trying to keep a charge on a siren module battery.
If you're lucky, you can solder in a new battery in the module. Mine was completely fried and took the circuit board with it. I replaced the module. Back then, it was about $180. Message resolved, alarm still works, no issues.
I removed the right front wheel and went in through the fender liner. You'll need a dremel for the tamper-proof bolts and a pop rivet gun to reinstall the fender liner.
