Results 1 to 10 of 13
Thread: HELP!!!!!!!!!
    Jul 2002
    Default Imported post
    Hi, my 98 XC with almost 57K miles is making me crazy. The warning lights for the Traction control system and the ABS system will come on together for a few minutes and then go out. Is this due to a lose wire in either system? Are those systems linked somehow? The other problem I am having intermittently is that when I first start the car, there is a sound like that of a jet engine revving up that is coming from the right side of the engine compartment. When this happened before, while under warranty, the dealer replaced the air pump. Now that that replacement is out of warranty by 3 weeks, the same thing is happening again. Have any of you experienced similar problems? If so, what did you find out or how did you fix them short of selling the car? Thanks
    Nov 2001
    romania
    Hi,
    (ABS+TRACS)I have a same problem, with my 850T5 '96.I change 3 sensor (ABS) and nothing is change.Finaly i change the computer wich control the ABS+TRACS , and now is ok.
    Be carefull, because when the ligts ABS+TRACS is ON, the ABS systems it does not work
    Romanian and Italian language.
    Guest
    Thanks for the response. In checking a couple other site (volvospeed.com and brickboard.com) I found some detailed info about exactly what you mentioned. There are basically 4 possible causes. According to the volvospeed site, the sensors are rarely the problem. It is more likely bad electrical connection on the ignition switch, a bas ABS/Tracs module or failure of the hydraulic block or pump. I checked my ignition and that's not it. So, as you said, I suspect the ABS/Tracs module has gone bad.
    Guest
    Similar experiences with my 98xc. The TRACS/ABS problem was intermittant, but very scary as I could feel it in the brake pedal. Ended up having to replace ABS module at a cost of $600 (this was about 2,000 miles out of warranty). I recently began getting the same 'jet engine' noise out of the right front side of the engine compartment. It goes away after a few minutes, but it can't be good. Let me know if you find out anything.  In 70,000 I also had to replace the steering rack, rotors, and a bunch of other stuff. Its the worst vehicle I have ever owned.
    Jan 2003
    I too had the same problem with our 98 X-C/83,000 miles.
    Replaced one wheel sensor/no fix. Determined it was the ABS control module that was the culprit.
    May 2003
    I don't know whether to be mad or relieved that there are others out there who are having problems with their 98xc's.  Since dropping off warranty at 50k our car has continually been in the shop.  I have told both my dealer and Volvo North America that after driving Volvos for the last 18 years, I'm finished with them.  There are too many fine Japanese cars out there without even a fraction of the problems these cars have.
    Hi, I agree with you brainjack about volvo losing their reliability in these first generation xc's, although I think '02 and on have improved a lot. There are a lot of reliable japanese cars out there but I don't know too many that look like or do what the XC does especially if you need the extra space. XC's have a lot of little electrical design problems and lot of emissions related parts that don't hold up like o2 sensors, check valves & air pumps etc. and I won't go into the possible awd problems. I might have got a bit lucky with my used '98 and currently the only thing that's bugging me is the bubbling door panels. You may have a good stretch of reliability once you get your repairs done. Good luck! ~Gerald
    Feb 2003
    </span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Gerald @ May 05 2003,20:52)</td></tr><tr><td id="QUOTE">I might have got a bit lucky with my used &#39;98 and currently the only thing that&#39;s bugging me is the bubbling door panels. You may have a good stretch of reliability once you get your repairs done.[/QUOTE]<span id='postcolor'>
    This was my thought exactly. &nbsp;I picked up a &#39;98 with 140k km and an extended warranty figuring everything that could possibly go wrong would while under warranty. &nbsp;So far that seems to be happening and since warrenty covers a rental I think that all in all it is working out pretty well&#33;
    As for the bubbling door panels, the service guy at my dealership suggested a body shop could use a syringe in inject glue into the pocket. &nbsp;Any thoughts on that or DIY?
    Jul 2002
    Southern California
    Unhappy Imported post
    No idea... &nbsp;on this one.
    As some of you know this is my 8th Volvo. All of them driven hard and long. &nbsp;The only one I have had an issue with was, ironicly, the first one (a 1980 245). &nbsp;It had been &#39;salvaged&#39; and the dealer did not inform be before hand. &nbsp;Which explained why the brakes did not always stop the car, why a lot of things did not work, why it did not always crank, or turn off. &nbsp;But soon I found my &#39;84 760, that had not had the engine wiring harness replaced and was a &#036;700 issue that was resolved. &nbsp;Later both fuel pumps died. &nbsp;But that was after I had put over 100k miles on the 760. &nbsp;None of the others (2 850s and the XC) have had any real issues.
    I still would not have any other vehicle than an XC or some other Volvo. &nbsp;Pre 2000 if possible. &nbsp; &nbsp;Especially after getting over 502 miles range on the last tank of fuel.
    LOGAN
    [email protected]
    1999 V70XC Cross Country
    2000 Nissan Frontier CrewCab 4x4
    Hi , I am also enjoying some good fuel economy. On a recent 1000 km trip we averaged 9.3 L / 100km. I&#39;ve decided to gauge mileage in these terms because its difficult comparing those different sized gallons myself being north of 49. I&#39;m pretty impressed that a car of this size and capability gets this and not to mention its an AWD&#33;&#33; Volvo sure got it right with these I5 turbo&#39;s.
    In regards to the bubbling panels, the vinyl they used simply shrunk and pulled away from the glued surface, and mine are stretched tight on a couple of doors. I wish the previous owner would have pushed harder to get the panels replaced. I&#39;m sure it would be &#036;1000 for all four now. If a guy had a panel off you would problably have to finish peeling off the vinyl, stretch it out without deforming it too much and contact cement both surfaces and carefully re-apply it and replace the panel. Ok, don&#39;t laugh at me&#33; It&#39;s possible&#33; &nbsp; Sorry for taking this thread off topic&#33; ~Gerald
