Page 1 of 7 1234567 LastLast
Results 1 to 10 of 61
    Oct 2011
    Northshore - Great Lakes
    Default 2001 V70XC - Angle gear o'ring at adjusting nut letting the fluid leak
    The fine space between the adjusting nut #14 and angle gear housing is making bottom of AG wet-to-a-drip.
    Is item #12 failing. How to scope the task and what to include while I am there. Is there a kit?
    Is it a screw off-on type replacement/repair?
    Quote Originally Posted by Xheart View Post
    Easy, just mark and measure before removing nut
    [ATTACH=CONFIG]7560[/ATTACH
    Mar 2015
    Sammamish
    I had a minor leak here too.
    I used a regular hammer and rubber tipped tool from the oem tool kit to move the part "one notch".
    Why one notch?
    It's my understanding that this device is apart of a preloaded mechanism in the transfer case- so I only felt comfortable going with a "notch".
    20k miles and it's still leak free (knock on wood).
    Mine leaks too. Replaced the smaller seal, to no difference. Did you "screw" it in by one notch?
    2016 XC60
    Could be item 3, the seal....
    If the angle gear is overfilled - it will leak more easily...what's the oil level?
    Oct 2011
    I had drained and filled AG carefully with proper amount - close to 680ml - some 2 years ago.
    I first noticed the wetness during the oil and filter change in summer.
    While on the ramp, removed the filler bolt and it dripped very slowly. Satisfied that there wasn't a dry condition, I cleaned and use my chalk method to cover the surface to help determine the flow and source.
    Found 2 drops on garage floor past weekend. Chalk markers have washed away.
    Block vent causing AG fluid heating, etc?
    Mar 2015
    Sammamish
    I had drained and filled AG carefully with proper amount - close to 680ml - some 2 year ago.
    I think that's very possible.
    Seal leakage is also a symptom of fluid that's been overworked.
    I have the data at home regarding the failure mode of differential fluid and it's influence on component and seal degradation-one of the main contributors for my switch 75w-140...It has a greater capacity to resist oxidation than 75-90.
    I'll get the data when get home.
    Oct 2011
    Quote Originally Posted by Iroll_ View Post
    I have a bottle of Volvo fluid PN 31259380. Is it 75w-140 grade?
    My next step is to drain and refill with new 75w-140 grade fluid.
    Mar 2015
    Sammamish
    OEM is 75-90.
    I am a proponent of a quality synthetic 75-140 in the angle gear as it resists shearing and oxidation more so than 75-90.
    Ford uses a similar angle gear set up in some of it's cross overs-they spec 75w-140.
    Grade/viscosity has nothing do with oxidation resistance.
    Changing the fluid before the additives wear out is how you avoid oxidation.
    Going heavier in grade isn't always "better". This is effectively splash lubricated. So, thinner might be better given the size and load on this assembly.
