I didn't pull the pan either time...but on the second time pulling the PCV system, a bent coat hanger, followed by a used .30 cal rifle brush (screwed into an old gun cleaning rod) allowed me to knock most of the carbon out from the top/block side...I had suction on the hole from a shop vacuum, but that just ended up getting messy, I couldn't really tell how much loose carbon I got...I sure got a lot of oil...and reckoned that was a good thing...though I needed a new shop vac filter when I was complete.
I was a little worried about some of the carbon getting in the oil, but it should be soft enough that if it gets past the pick-up screen, that it won't damage the pump and big enough to get caught in the filter...
If I had had more time, or a better idea of what was wrong, I would have pulled the pan on the second set of work, simply to preclude any carbon getting in the pan, and because it would have been easier than removing the manifold, and because it would be a straight shot up to the passage that was blocked.
I had cleaned the block fittings when I did it the first time...thought I had done a good job, but I didn't get all the way down to the oil pan...my mistake...
