I'm starting to research / get all the parts lined up for the control arm bushings and ball joint replacement .. still have a rattle going over bumps. I'm trying to keep everything OEM. I've found that the OEM bushings were made by ...
front: Lemforder,
rear: Febi / Bilstein
These appear to be the OEM ball joints, can anyone confirm?
http://www.eeuroparts.com/Parts/5685...Bolts-274548G/
They're a little spendy at ~$75 each. Has anyone used the Febi's that are a little more economically priced, if so how did they perform??
http://www.eeuroparts.com/Parts/9043...-Bolts-274548/
According the to records I have from when I purchased the car, ball joints were replaced at 91K miles and again at 105K. Seems to me you should get more than 15K out of ball joints? The original set appears to have made it 91K miles..? Currently ~128k, so I'm wondering if they even need replacing? I'm kind of thinking since I'm going to have the control arms off, why not just replace ball joints while I have everything torn apart? .. or is this bad logic?
