Hello,
I'm ordering up parts for a front lower control arm, ball joint, and bearing replacement this weekend. Inner tie rod ends and stabilizer links were done ~20k miles ago, so I'm assuming those are still good. The bearings and ball joints seem pretty straight forward, but I am looking for some expertise on the best way forward with the control arms.
When I inspect the control arms only the bushings appear bad. The control arms themselves look to be in decent shape.. it's a block of aluminum, I don't see what can really "go bad" on them? When shopping around locally for replacement bushings, the parts store mentioned that getting the bushings out and back in (properly aligned) to the control arm can be tough. Has anyone swapped the bushings and reused the control arms? I don't have hydraulic cylinders and special tools referenced here: http://www.volvoxc.com/0/resources/h...m-bushings.pdf .. Is it worth the extra $80 for new control arms (preventative) while I've got everything torn apart and don't have the proper hydraulic tools, etc.. ?
As for vendors.. I'm looking around on ebay and AM AutoParts, Deutsche Parts, or 1A Auto seem to be the predominant choices; is there a consensus around here on who has the best quality/value parts?
Thanks All!
