Hi all
I'm a new V70XC owner and i'm already having loads of problems with this baby. This current one i'm trying to fix is the engine coolant leak.
I've identify the leaked coolant which can be seen if you look top-down on the driver side near the radiator. But I still don't know where it is leaking. Another sign which worried me was that there was some white smokes coming out from the middle of the radiator near the air intake after I drove the car for a while OR keep on changing gears (R-N-D) until the car warmed up.
I've brought the car to a shop and they did a compression test on the coolant system which found no problem but the radiator cap test failed (which means the cap can't keep the pressure) and they recommended me to replace the cap. I decided not to go ahead because they were going to charge me $60 for the part + $75 for 30mins labour + engine coolant refill cost. This is Australia! I was happy to pay $72.50 for their compression test.
I want to know if the radiator cap is the problem then how did the coolant leaked out and remained at bottom of the front bumper. And also if the cap failed, would it be able to cause the radiator to overheat and produce some white smokes?
I've purchased the radiator cap ($35 online from Melbourne) and i'm waiting for it before fitting it myself. Note that they have refilled my engine coolant and it passed the MAX mark on the expansion tank.
One more thing, my private mechanic told me that I need to replace the radiator which I thought was reasonable and I bought the radiator from the US ($350 for OEM one) but I'm waiting to see if replacing the radiator cap would fix the problem.
Today I drove the car to work (20mins) and I found some (very light white smokes that you have to focus to see it) came out from the same area but I wasn't sure if the radiator was overheating or not.
Can you guys give me some ideas....Thanks in advance
