Attempted to replace both front axles. Right side went smoothly and was done in 30 minutes or so. Left side did (is) not going so well. I can not get it to disengage from the tranny. I have try pry bars and even plastic splitting wedges with no luck. I see the instructions specify the use of a special jimmy tool, but does anyone know if this tool slips in around the shaft or just grabs the beveled part of the inner coupler. The reason I ask is that I only have about 1/8" of clearance between the tranny and the coupler, which makes it difficult to get any type of a good pry on it and I don't see how a tool thin enough to fit in there would be strong enough to pry with. Does this clearance seem right to folks that have replaced these? I'm leery of prying too hard and potentially cracking the tranny case. Pure speculation on my part and don't even know if it is possible, but could the axle have been inserted too far and the retaining clip gone past the retaining groove and out the back letting it fully expand behind and making it impossible to remove without breaking something? Only picture of the internals I could find was from a '95 850, so I'm just speculating they are similar.
If folks say the ~1/8" coupler to tranny clearance is about right, I'll feel a little better that this is not the case and will attempt with more force. I'm about the the point of drilling into the couple to attach a slide hammer, but then there is no turning back.
Any experience and thoughts on this would be greatly appreciated. At this point I'm being very cautious as a mistake could lead to big $$$$s.
Thanks,
Rob....
